JK_Dave
I don't understand how hydro steer will fix all your problems
It won't but I sure hear that a lot :crazyeyes:
It's funny, the guy that checked the alignment was telling me he sets all his alignments up with cross caster. Which then he was like it helps to compensate for the road crown. When I asked about the strain on a solid axels, he then started acting like I was meaning that my gears were welded and locked. That was the point I just got my print out, said thank you for his time and left. The people that work on cars amaze me sometimes. Maybe I'll just go ahead and by the hydro steer and be done with it all...:thumb: thanks again for all your guys help!
I'm late to this thread too but was gonna add two comments:
If it's radial pull from tires, you can test this by swapping the front tires and seeing if the pull switches. Never found a radial pull from tires to only kick in during acceleration, though.
In the past, when I had a pull during acceleration that reversed when decelerating, it's always been a loose control arm or worn out control arm bushing. The give away is the reversing pull when letting off of the gas.
