JeepJeep75
For sure. I'm just wondering exactly what he's talking about.
Ah. Totally jumped the gun there. Pics would be good.
they groan and rumble, have play......as any wheel bearing does Usually easy to catch coasting down a hill with engine idling, or lifting the wheel and listening to it spin with a long screwdriver or better a stethoscope to the fixed part of the unit and you ear(s) (better to have a helper to prevent injury)Thanks for the great write-up! Considering doing this as I have been chasing a rotational squeak around my front passenger for months now. It will come and go but when its there, its annoying as all get out. Squeak increases in frequency as wheel rotation increases. I mostly notice it when under 5mph on downward slopes such as coming to a stop sign. It sounds similar to shitty bicycle brakes but I don't believe its pads or rotors. I have had the pads a while and greased all the clips and pins when they were installed. I've done all the tests I know of getting under the jeep and shaking things around feeling for play, but everything seems solid. What do hubs sound like when they go bad?
Eddie, will this fit a 2014? The Amazon link is telling me it doesn't fit my 2014, I want to replace them now that my PR44 was shipped...
Thanks for the write up.
I’m wondering if anyone has seen a bad bearing chew up the end of an abs sensor. I replaced the front driver sensor four months ago, and it died within a month. My bump stop broke and I assumed it was bottoming out or over extending and breaking a wire. So I was replacing the bumpstop and abs sensor and I noticed the tip of the sensor was chewed up like my Labrador got a hold of it. I put the new sensor in and I had to give it a pretty good push to get it seated. I’m thinking the bearing could be skewed off a mm or two catching the sensor.
Thinking I’m just going to get a new bearing and swap it out as there is a bit of vertical play anyways.
Should this be done in pairs? Anyone have suggestions on brand or is Timkin still considered equal or better to OEM.
2013 jku, 80k miles, 35” tires for reference.
Yeah, when I was shopping around for a pair, I saw that too. You can get cheaper ones than the Timkens I got but, Timken makes quality bearings and so, I decided to go with what I know.
Will this still fit a 2016 Jeep Wrangler rubicon the one Eddie used.
