Listen to this guy, he knows what he’s talking aboutI ran mine directly to the battery. It was straight forward and if needed, there is always the on-off switch on the fridge.
Yes, the switches can be configured a few different ways by using the setup menu...So I have an ARB fridge wiring kit that I have never used and I’m thinking of adding the plug to the bed of Jabberjaw. Can I run it to one of the four factory Aux lines or should I run it directly to the battery? (Related question, can the factory Aux switches be set to keep running power even with the key/vehicle off?)
The stubby antenna was my first mod.Thanks! I’ll hopefully get that wired up this weekend. Got my stubby antenna (I hate the big factory one) and 110 pigtail installed. Watch Eddie’s write up on the decked and install the 110 before the decked if you can. It’s doable after, but kind of a PITA.
Those little hands you have ain’t just good for one thing.Thanks! I’ll hopefully get that wired up this weekend. Got my stubby antenna (I hate the big factory one) and 110 pigtail installed. Watch Eddie’s write up on the decked and install the 110 before the decked if you can. It’s doable after, but kind of a PITA.
You know it! They make everything look bigger.Those little hands you have ain’t just good for one thing.![]()
Are you running the screw in ARB plug? I can’t decide whether to run that or swap it out for a standard 12-volt.I ran mine directly to the battery. It was straight forward and if needed, there is always the on-off switch on the fridge.
What can you actually run with the 110 power? Would it power let's say a electric chainsaw, worm drive or a hedge trimmer. I hate pin stripes so a hedge trimmer would kind of cool. Awhile back I saw a Youtube video of a head to head of jeep and something else. They guy in the jeep came to a over grown part of the trail and didn't want to pin stripe his new jeep, so pulled out some hedge trimmers and it wouldn't power it enough.Thanks! I’ll hopefully get that wired up this weekend. Got my stubby antenna (I hate the big factory one) and 110 pigtail installed. Watch Eddie’s write up on the decked and install the 110 before the decked if you can. It’s doable after, but kind of a PITA.
I haven’t tested it yet, but I imagine it will run my portable Traeger, charge my Yeti, run a blender or coffee grinder, and charge the batteries for my power tools. Beyond that smaller stuff, I have no idea.What can you actually run with the 110 power? Would it power let's say a electric chainsaw, worm drive or a hedge trimmer. I hate pin stripes so a hedge trimmer would kind of cool. Awhile back I saw a Youtube video of a head to head of jeep and something else. They guy in the jeep came to a over grown part of the trail and didn't want to pin stripe his new jeep, so pulled out some hedge trimmers and it wouldn't power it enough.
I'm running the screw in ARB plug and leaving enough wiring loose in the bed to double back through the back window in case I want to run something in the cab of the truck. That way a fridge could be used in the truck bed or inside the cab depending on the set up for the trip.Are you running the screw in ARB plug? I can’t decide whether to run that or swap it out for a standard 12-volt.
Don't forget( unless the new Gladiators have addressed this ) the plug only works with the engine running. That is why I ran the ARB wiring kit to the bed of my truck. When I use a fridge, it stays plugged in and on as long as I have it switched on. Just run the JT for about 10-15 minutes every couple of days to make sure the battery has enough juice to start the engine and get you home.I haven’t tested it yet, but I imagine it will run my portable Traeger, charge my Yeti, run a blender or coffee grinder, and charge the batteries for my power tools. Beyond that smaller stuff, I have no idea.
This is correct and important to knowDon't forget( unless the new Gladiators have addressed this ) the plug only works with the engine running. That is why I ran the ARB wiring kit to the bed of my truck. When I use a fridge, it stays plugged in and on as long as I have it switched on.
Outstanding!Plates are in.
I like this explanation the best. I had no idea it was a show but I’m also not old as fuck like some of y’all.Probably not many. Most people will assume it has something to do with lawyers never shutting up.![]()
