jeeeep
Has anyone used Mopar CCC combustion cylinder cleaner? I've heard good things and watched a few you tube videos. Lotsa smoke after running spraying it down the throttle body and letting it sit for 6-8 hours to "dissolve " crud. Is it really burning out bad stuff or just burning the Mopar additive??
as sensitive as the Jeep system is, i don't think i'd spray anything down the TB. It's pretty easy to remove the TB and clean it out - imo removing it to clean it would be better than spraying any build up down into the engine.
i used to use TB cleaner direct on my older rigs and they would blow a lot of smoke as all the crud burned through but they weren't as sensitive as these new systems are.
![20160921_123829[1].jpg 20160921_123829[1].jpg](https://www.wayalife.com/data/attachments/207/207133-7fc52e69bd71132ab806d00beef834f9.jpg)
