:crazyeyes:
What a surprise - Thought you were going out to get your "nice clean jeep muddy again" :rolleyes2:
First correction dust seals are no longer in axle after RCV install.
As if that makes a difference but, okay. So you've been installing and removing shafts just like I was trying to illustrate.
Filled with not quite 1.3 qt. of gear oil after completing install of trusses and axle install.
Don't know why you would have installed a truss being that axle housings never bend. Just sayin.... :idontknow:
This Friday will be four weeks and no leaks since properly filling it. According to your previously stated rant I SHOULD STILL BE LEAKING GEAR OIL or my axle is bent!!! Your premise is once leaking always leaking.
I realize you're all upset but please try to slow down and read what I said one possibility was that, "you could of had gear oil leak into your axle tubes during the install of your RCV's and then in the process of driving around, it leaked out of outer seals. Once everything worked itself out, you had no more leaks." In this scenario, it was never really leaking to begin with but rather, gear oil came out with your during the shaft install and it stopped leaking after it worked itself out. :naw:
Yes and no maybe more yes but that isn't what I asked him and after question stated what I learned from my experience.
So it was a loaded question and one that I simply disagreed with.
Two the vent line breaths in and breaths out so as to keep the pumpkin at the same atmospheric pressure otherwise the oil will find the path of least resistance out. Maybe cover seal, axle seal, pinion seal or breather tube. Now you have a snorkel of sorts so what do you do with a snorkel so not as to aspirate water. Hold your breath but an axle cant do that. Now you add a dust/air void to keep the water out if you are in that position. Yes primary effect let the axle breath secondary is keep water out because the primary now allows water penetration. Cause and effect!
Ummm, since you seemed to have missed it, that is what I said - that's what the breather "primary purpose" is and the tube is routed high to keep water out :idontknow:
Now your personal attack or lambasting! You do realize you are a 1%? That 99% of other jeep JK owners never ever come close to your level in a road legal form of performance and modification to there vehicle. You see a lot of the uncommon that most of us will never see! With that said so what gives you the right to say this is black and this is white in every case and scenario and don't give me the BS this is your sand box!
But it is my sand box and all I did was share what I think. Nobody asked you to be here and nobody said you had to agree with or even like anything that I say. Don't like it, don't let the door hit you in the ass as you leave but if you choose to stay, try not to get so butthurt over every little thing you don't like to hear. :naw:
Right now I would love to shove my diamond studded 4x4 shifter up your royal Doberman arse and twist it for effect!!
:shock: You have a diamond studded 4x4 shifter?? Now that is something I would love to see - no, seriously, please post up a pic of that :thumb:
That's just my barbaric German ancestry talking and since I am a good Christian I forgive you but belittling come on!
No, I'm quite certain I'm hearing a self-righteous Christian talking :yup:
Your looking for a fight how you tear into people!
If that's what you choose to believe, who am I to question your faith.
And no I am not keeping stats on you. I just remember others that have befallen your keystroke and you are very effective.
Okay, I get it now. So, even though I can't recall a conversation I've had with you where I've shown where you've presented incorrect information, you're carrying the pain I've somehow caused others on your back and making them yours. Got it :rolleyes2:
I like your web site and read it often but I will not back down from what I feel is not accurate and not warranted either!
Never said you should. But, I am right here and you just confirmed it. The least you could do is admit it. :idontknow:
You pull peoples opinions apart and out of context and twist, turn then pounce with a personal transgression for effect hence the "Not trying to inflame you but, do you ever wheel your Jeep?" and "I will and hope you have fun.
I'm sure it's hard for you to see the log in your own eye when all you can do is look for the spec in mine. Just giving back what you dish out.
If you shift into 4WD, you can even say you went "4 wheeling"" you don't know a damn thing about me to even make a half witted thought about me! You have maybe, and I'm stretching this at best, 1 kilobyte of info about me unless I give you more!
So enlighten me. For the most part, the only reason why you're ever on here is to prop up Motech and their LS kit. I mean, it's good information and looking through your post history, I don't ever recall giving you grief about any of it but, I can't say I have ever heard you talk about wheeling. Just sayin :idontknow:
As I don't know you very well either except in type why would you pounce unless you feel threatened?
This is a forum as in, a place where people share information, discuss ideas, offer opinions and god forbid, even disagree with people from time to time. Don't like it, you might want to go back to your self-righteous church where I'm sure everyone always agrees with each other.
I am not doubting your experiences or others but these are just random thoughts spewed out in ones and zeros via an IP protocol via air, wire or fiber directly to your door. No feeling or touch just thoughts! They need to be treated as such. If we were all exactly alike maybe we could pull some feeling out of a sentence based on like patterns and rhythms but I cant and we definitely are not alike!
Well I certainly hope we're not alike. :crazyeyes:
I could give a shit less what you have, what you done, or who you are under the cover of "I say it like I see it.
Never said you should "give a shit" but apparently, you do enough to want to shove your diamond studed 4x4 shifter up my ass :cheesy:
I care about the interaction of humans not humans that act like dogs!!!
To be clear, what you care about interacting with people that think and behave just like you. Those that don't are "dogs" :yup:
