cosmokenney
I have a 2019 JL 2 door Rubicon. I wanted to build a very capable backcountry access vehicle out of it. Something that would easily get me through any unmaintained forest service road to go fly fishing or camping or in winter, to the start of a backcountry skiing ascent. There are a lot of roads like that here in northern California and some are more like OHV trails than roads in terms of technicality.
I did what I'd consider a modest lift at 2.5 inches and went with 37" tires to maximize diff clearance. I went with a full Rancho lift. Including their heavy duty upper and lower, front and rear, control arms and trackbars. That almost immediately lead to a shimmy in the steering that started getting more and more noticeable. Now, at 32 - 36 PSI in the tires, it is close to wobbling but doesn't go crazy. But if I am aired down it goes full wobble. And since I use this jeep almost exclusively for off road driving, I tend to just leave the tires at between 17 and 20 psi. The wobble kicks in as soon as I go over 46 mph and hit any kind of bump -- on pavement.
So now that I have started experiencing DW, I threw some money at it. I installed a Rusty's frame-side track bar brace, Metal Cloak drag link and tie rod. TeraFlex HD ball joints. And already had a Fox TS stabilizer that I got covered by the steering stabilizer TSB. I also installed the shouldered 9/16" trackbar bolts.
After I installed the lift, I had a shop that WFO Concepts recommended do a full alignment. And all wheels where balanced. After I installed the tie rod and drag link, I double checked the toe and caster (at home).
I am starting to suspect the Pro Comp wheels might be part of the problem since, it turns out, they are lug centric. So I am considering selling off the wheels and 37" pats. I am also considering down sizing to 35" tires when I get the new wheel/tire setup. But that, is kind of my dilemma, I had 5:13 gears installed. And I kinda think that would be pretty low gearing for 35" tires. And there is no way I can dump another $3k to regear again.
I should also note that I have total of about 3000 - 4000 miles on the lift and probably 1/2 that on the steering components and ball joints. And if I am being honest, I almost feel like the metal cloak steering components made matters worse than stock. Everything has been retorqued since the initial install. And when I did that, I found that the front UCA jam nuts were finger lose -- so much for the high $ alignment.
