Destroyer
Hey Guys,
So I've recently had issues with my battery. I thought it was dead, nevertheless after a quick check I noticed that the (negative) ground wire to the battery is a tad loose. This caused the following: the jeep to shut-off quick, the jeep not to have power and when driving and hitting a bump it would cause my ABS and Traction control to turn off.
I'm curious to know what methods you have used to tighten down the connections on your battery? What has worked the best for everyone? I'm going to assume bumpy roads and off-roading hasn't helped me. Want to make sure those connections don't come loose again.
Options from what I've read:
1) Lynx Battery Cap
2) Install new Gold Terminal ends clamps
3) Cut a copper pipe enough to fill the void of the terminal end
4) I've heard of copper band or copper tape
Nevertheless, I do plan on replacing the battery either way as it's probably time.
Thank you in advance!
Oh, and after doing some research I probably should remove some of my aux cables of the tightening nut, lol. That's probably my issue...either way if you guys have a pic of your batter setup please post it!
1) Lynx Battery Cap
