This may be a really dumb question but to paint the ring should I deflate the tire some before removing the ring or can I just remove the ring? I was thinking off jacking it up and deflating before removing the rings to prime and paint but not sure if that’s over board. Will the tire lose pressure if I just remove the ring?
Welcome to Wayalife. You’ll probably die if you do that.
Take some of these things from staples and put them over the bolt holes then cut some cardboard out to protect the inside of the wheel and tire.
Then when you’re done just pull the stickers.
Probably wouldn't die...but you might have to change your shorts and count your fingers...
Haha I figured it might be alone those lines....still don’t want that either. I’ll try painting while mounted.....gonna get scratched off anyways just not a fan of the silver when everything else is black or orange
If they have never been painted I don’t recommend the way I suggested. That is for pre painted rings. You’re gonna wanna scuff the ring and prime it before color.
What wheels are these? I’ve been trying to figure it out since the thread started, they turned out great!New wheels assembled!
Very very happy! [emoji51][emoji51][emoji51]
