J
JKDream
Guest
Once i installed the transmission cooler the hot oil light did go away under hard driving
That was one of my issues as well. I originally had overheating from the mud, but it was actually the transmission overheating.
On my 2013 the transmission cooler is built into the radiator, so it wasn't cooling properly.
That's where your problem might lie, the transmission opposed to the engine.
Mine still gets hot some days, but never enough to ding the oil light on, and that's perfectly normal.
How long ago did you replace the transmission? If you've had the hot oil light since then, I'd replace the fluid.
It's typically burnt after that light comes on.
** You might want to make sure they put enough fluid in the transmission as well.
A lot of shops mess this up. Especially if it was a new transmission, they might have underfilled it.
