Seahawkfan
Some of these shops that do this work have it down to damn near factory installs. Not sure where you're all getting this extra $ 30,000 from? AMW4X4 list's the basic 392 w/ 8 speed for $35,000. I don't see where it says plus labor.? (Pulled up a crate 392 for $9600.)I don't know if you've seen videos on this swap being done - but its not a painless conversion and imo looks like more of a pain than its worth (especially given the fact that hemi's and 8 speed zf's are not cheap). If you can find a wrecked charger/challenger with a hemi would probably be more feasible but then you have a used motor that you have no idea what its condition is in. From what I seen the cutting of mounts, rewelding, the custom adapter for the transfer case , new crossmember etc ... i'd pass on all that and buy a new/used 392 instead (which already has the correct high mount alternator and properly angled intake). I wouldn't attempt this conversion unless I had my own shop. The $30k difference can EASILY be eaten up by odd ends and bits and Labor especially.
They do state install time, doesn't say extra. For example, JK install time 48 hrs (lets say $125 hr X 48= $6000+$9600=$16,600. $35,000-16,600=$19,000 for a tranny and whatever else that is needed.
I believe it has more to do with what you're starting with. If you have Jeep (even a JK) that's still in pretty good shape and has a good, let's say $10,000 and up suspension set-up, $5000 wheels and tires, $5000 bumpers, $5000 plus paint Mopar half doors and then there are 1-ton axles $18,000. Would probably be okay with Dana 44's w/upgraded shafts for a while. (could be wrong) So, you have let's say $25,000 to $40,000 in quality parts into a rig with no payments.
It's a no brainer to have a Hemi (or LS/LT) swap. Used still stock Jeep 392's $70,000 and up. New $100,000.
I think I could live with an improperly angled intake, and some welded in parts.
I'm pretty sure they even finance as well.
Disregard if they are asking $65,000 for conversion. But I highly doubt it.
I wouldn't or couldn't do this on my own either. But I bet there are a bunch of guy's/girl's on here that could.
my 2 cents
