dyn0mitemat
Double check track bar bushings and that the bolts are torqued to spec and are not sliding around in the mounts (as the factory has the holes a bit sloppy, oversized).
I'll double check that as well.Double check track bar bushings and that the bolts are torqued to spec and are not sliding around in the mounts (as the factory has the holes a bit sloppy, oversized).
I noticed you and WJCO both mentioned returning to stock stabilizer. I have been hearing some chat/rumors about aftermarket stabilizers not working well with the electronic steering in the JL/ JT’s . The explanations I have heard were something to do with pressure fluctuation causing DW. It didn’t make much sense to me. Locally I have had a couple friends with completely different brand components experiencing DW and going back to the factory stabilizer was part of the solution. So I’m curious what prompted both of you to suggest this. I apologize if it has been discussed on another thread. I haven’t been on much lately so I may have missed it . It’s hard for people often times to take “upgraded” parts off to solve a problem after spending a fair amount of $ on them. Can anyone elaborate on this?For now, I would try reinstalling your factory steering stabilizer.
What does your alignment look like now in terms of numbers?
If you have the means, I would check your ball joints to see if they are worn. I have had JK ball joints go out in as little as 4k miles.
A member here, doubletapdaddy, who is mechanically inclined, had a shit ton of death wobble issues with his JL. He had done a bunch of mods at once. He double and triple checked everything. This went on for months and he stopped driving his Jeep because of it. The ultimate fix for him was removing his fox stabilizer and putting the OEM one back on.I noticed that
LOL - holy fuck... welcome back from like JUNE!!!I noticed that
Yeah it’s been awhile. Life’s been busy. New Granddaughter and all. Kinda weird I don’t feel like a Grandpa. Lol!LOL - holy fuck... welcome back from like JUNE!!!
That said, maybe you should try "noticing" the part where I say "for now...", as in, just to see if it makes a difference.![]()
I had the same problem with my JL with the updated OEM steering box. I smashed my stock stabilizer so I “upgraded” to a Fox and synergy relocation kit. The wobble and erratic steering was pretty bad. Eddie and the guys suggested trying a new stock stabilizer and it solved the problem.A member here, doubletapdaddy, who is mechanically inclined, had a shit ton of death wobble issues with his JL. He had done a bunch of mods at once. He double and triple checked everything. This went on for months and he stopped driving his Jeep because of it. The ultimate fix for him was removing his fox stabilizer and putting the OEM one back on.
You can read the whole saga here (this link points to the post where it finally went away) : https://jlwrangler.com/threads/dbltaps-mojito-jlur.1899/page-39#post-61554
To be clear, a steering stabilizer will NOT "cause" DW but one versus another CAN do a better job of preventing the kind of oscillation that WILL. The JL/JT is a different animal in that is uses an electric steering pump and has/had an aluminum steering box that is known to cause problems so all things being equal, I always recommend going back to OE just to see if it makes a difference and while you're trying to figure things out. At least on a JL or JT.Yeah it’s been awhile. Life’s been busy. New Granddaughter and all. Kinda weird I don’t feel like a Grandpa. Lol!
The steering stabilizer thing is interesting. I don’t quite understand why it would/could cause DW but it seems to be the common denominator for a lot of people dealing with it. Chrysler obviously has been fighting with it too between the recall and TSB’s about it. I was hoping you had a better understanding of why some brands of stabilizer’s don’t play nice with them. Just doesn’t make sense to me. I am getting the JT bug pretty bad so time spent now researching will hopefully save me some headaches later.
I can't speak for anyone else but I personally noticed more steering issues when it was cold out. I do know of others who experienced the same. I have NOT had any problems what so ever since installing the Synergy track bar reinforcement/sector shaft brace.I've been out of town, so haven't been able to get a toe measurement yet, but I did do a little deep dive and found the old posts about death wobble with the early JL and JT models. Was there any definitive answer to wether or not the temp played a role in the death wobble or steering feel. It was in the 60s in vegas today and driving around I almost want to say it felt a little better driving it around.
I had that synergy sector shaft brace installed before I lifted the Jeep. Had it removed so I could get the steel steering box installed. Steering felt the same with it off but I only drove around for a few weeks before having the steering box replaced. At the moment, I haven't put it back on yet.I can't speak for anyone else but I personally noticed more steering issues when it was cold out. I do know of others who experienced the same. I have NOT had any problems what so ever since installing the Synergy track bar reinforcement/sector shaft brace.
That is pretty cool, thanks for sharing.Those alignment bars are stupid expensive for what they are, get yourself a few short sticks of 1" x 1" x 1/8" angle and drill a few holes in them
Whether you buy them or make them I can’t think of a safe way to put the weight on the knuckle with this type of tool. Seems to be a accurate enough. I do set my stands today be as close to ride height as possible. Toe and steering wheelGreat idea, thanks. I see you have the axle on jack stands, do you believe you’re getting an accurate measurement? I know some say there needs to be weight on the knuckles for the measurement to be accurate. I’m curious because I’ve wanted to buy or build a set of these too. Thanks!
Nice, I think I’ll make a set of these then. Thank you.Whether you buy them or make them I can’t think of a safe way to put the weight on the knuckle with this type of tool. Seems to be a accurate enough. I do set my stands today be as close to ride height as possible. Toe and steering wheel
seems to get knocked out of whack a little on every hard wheeling trip I do
I have cross checked by scribing a line on the tires and using a tape measure or I also tried a toe gauge (bar with uprights) like they used to align cars before they had laser alignment racks. The toe gauge doesn’t seem to be designed for 37” tires, the spot you line up with the scribe marks is near the bottom of the tire. I think it was more designed for passenger cars and smaller trucks.
I have also done an alignment using strings on each side of the Jeep but that was after doing the long arm conversion to check the thrust angle and a few other things
