Wardell
I noticed that the wiring kits from mopar are different for the 2010 vs. the 2015. It seems to be the different HVAC controls. If I get the hard top will it fit and function properly on my 2015? I would hate to have fit issues with the freedom panels or issues with the wiring.![]()
The wiring is for the rear window defroster and wiper, and there is also a hose connection for the window washer fluid. It won't effect the heating or air conditioning system at all even if you don't connect it, you just won't be able to use these for your rear window.
If your Jeep was originally sold with just the soft top, it might not even have the wiring or hose installed. If it does have it, it's probably tucked in at the driver's rear corner, either just under the lip of the tub or just under the upper corner of the carpet. If it's not there, I think it would be easy enough to order the wiring that goes with the top you're buying and install it yourself. Otherwise, I'd bet you can adapt them to work together. I don't know of anyone that has done this though.
