Here are some pics finally. Had to dig some old ones up of it on the jeep.
The good: it's a beast and made in the USA. Has built in antenna mount, d-ring mounts, and high lift mount. I added the uprights as I needed mounts for the ambers for JKX. Clears 37's on coil overs without rubbing whereas the stock bumper would get rubbed off. No dents, matter of fact I don't know if you can dent this thing. The price. Selling for $600. This new is $1400. In fact just the bumper portion is $800 new. If you want to run the bumper only you could remove the carrier and still save $$$. $l
The bad: I run 37's on heavy Atx slabs. I would have to push up on the tire carrier when shutting or it would drag on the bumper near the latch. This can be seen in the pic. It can be adjusted higher as well but it makes it harder to move. With lighter wheels it should be fine. It could use some spray paint. But then again it isn't supposed to be pretty. It's supposed to hold a tire and not take shit from anything. It does that all day long.
