Rifle rack
I've been toying with the idea of how to carry my hunting rifle in the Jeep.  There aren't a lot of options out there that fit the bill:
1) Rifle must be pointed upward when be transported.  No horizontal mounting
2) Must cost less than $50
3) Must be able to be used with doors on.  Hunting season is usually chilly.  We're not running around the Rockies in the snow with the doors off shooting elk as we go.
4) Need not be inconspicuous.  I don't keep my rifle in the Jeep at all times; only when hunting
5) Must be able to access it quickly from the drivers seat
With those in mind, I set to work.  I went through a few different ideas before settling on this one.  I'll write this in the form of a how-to should anyone else want to replicate it.  Final product is at the bottom.
SUPPLIES:
A 3' piece of 1"x1/8" aluminum stock from Lowes/Home Depot ($5)
3 cans of black plasti-dip.  Not the spray on kind; the kind where you actually submerse the part ($6 each)
1 Quart plastic pale with lid.  Available in paint department of Lowes for about $2
A few washers
A tire you don't care about (Discount Tire hooked me up with one they were going to toss for free)
A few small pieces of rubber for washers/spacers or some actual rubber washers
Super glue
A vice and hammer/mallet
A drill and some drill bits
A dremel tool or similar
Razor blade
Patience
Here is a shot of the Jeep and rifle in question:
I decided on two anchor points, with the bottom anchor point being the sturdiest and taking most of the weight.  It bolts right on using the existing bolts that keep the door from opening too wide.
First step is to cut about a 8" long piece (better too much than too little) of the aluminum stock and mark out the spots for the holes.  Then drill each hole wide enough for the existing torx screws to fit through.
Next, spend some time working with your mallet, vice, and 8" piece until you get a shape that looks about like this:
Be sure to test fit frequently throughout this whole project.
Before bolting it back on and testing fit, you'll want to protect the finish on the inside of the door.  I found some spare rubber around the shop and made two little washers/spacers, one for each hole.  You can barely see them in this pic:
They're just super glued on the back to hold them in place.  Re-drill holes with rubber spacers glued on.
Here is a pic of me lining up where the rifle will eventually rest:
Next up is the top piece.  There's no really good place to bolt on up top.  The two bolts you can see are entirely for looks and can't bear any weight.  So I went with a snap in piece over the grip in the door.  It'll use friction to snap on and the weight of the gun keeps it in place.
Here it is in-process:
Test fitting it:
Final shape.  See pics farther down for full geometry of the hook.
Next up, time to take a knife to that old tire.  Alternatively, you can skip this part and just plasti-dip stuff if you don't want to hassle with it, have confidence in the shock-absorbing materials of plasti-dip, or the two pieces that we've made so far don't contact sensitive parts on your rifle.  Notably, the bottom piece could probably just be plasti-dipped with no rubber insert.  My top piece touches my scope, so I wanted more cushion there.
Cut two 8" pieces of rubber, 1"+ wide.
Using super glue, attached them to each piece, and trim with razor blade.  Be sure to clean both parts before gluing.  Once glued down, you may want to go back and add some more glue in areas that are sticking up and get it all down firm.  Doesn't have to be absolutely perfect; plasti-dip will help fill in. Here is what they look like after this step:
Next up, we're going to be adding an auxiliary supporting piece, just to make sure the rifle doesn't come unseated from the bottom piece.  This one takes some patience as it requires some funny angles to get around the bottom, mesh, storage compartment on the door.  Be sure to test fit a lot.  Once you have it worked out, super glue it to the first piece and drill out the hole.  Should look like this when finished:
With that new piece on, we'll need to add some washers so everything still bolts down flat.  Super glue two together and then to the top hole:
Time for plasti-dip!  A few notes on this.  First, plasti-dip will eat through styrofoam it turns out.  Second, these pieces are too big to fit in the plasti-dip can.  That's where the 1 quart plastic pale comes in.  Pour 2.5 cans of plasti-dip in that and be sure to keep the lid on when not in use.
Here is a shot of the bottom piece right after dunking the bottom half of it.
And here it is finished and dried.  I had to do the bottom half, then top half, then bottom half, then top half because the part is still a little large for the 1 Quart pale.  You could go big and get the 2.5 Quart pale and 6 cans of plasti-dip.
FINISHED SHOTS
As seen from outside.  It's obviously visible, but like I said, I wasn't going for anything beyond a place to put it while hunting or out in the country.
With the door open.  I really like the way it swings out of the Jeep with me.  No more awkwardly climbing out while trying to hold my rifle.  Just get out and it's right there in front of me.
This is a shot of me sitting in the drivers seat.  Leg just rests up against it.  I'm 6'3" and it doesn't hinder me at all.
As seen looking through the Jeep:
Hope this helps someone else!  It took about 6-7 hours total to get the bends all correct, but it was fun and now I have a place to hold the rifle while out driving mountain roads looking for deer and elk.
