GraniteCrystal
Rotopax Review
Rotopax Review
Original Writeup:
http://wayalife.com/showpost.php?p=711283
I'm pretty disappointed with these. I live at 5,500' and often go up to more than 10,000'. This trip we went to 13,000'. Before the trip, I did my best to fill up the Rotopax gas can as full as possible. This should limit the expansion of whatever vapor is left inside at higher elevations or when subjected to heat (i.e. the sun). It's pretty hard to get all the air out though so there was a small pocket of air still in there. Just with that small amount, I still found the can to be swelling as we climbed. I did my best to relieve the pressure, but that's a huge pain to do when your cans are mounted by weaving a tie-down through them on the roof rack. A couple days in I relieved the pressure and then went to mount the can again. It leaked. This isn't the first time this has happened where it develops a slow but steady trickle leak. I cranked down on the sucker are hard as I could, but as soon as the can inverted it started dripping. Not sure what's going on there. Only seems to happen at higher elevations after it's been expanding. Seems like a lot of money for a can that develops a leak fairly easily.
Conclusions: I need to find a way to bleed the pressure off the can in real time so it isn't swelling. I think I'll
1) Call Rotopax and see if I can get them to send me a new one, explaining that this one leaks
2) Mount the cans vertically. I'm thinking on the tire carrier or vertical mount on the side of the roof rack. Then I can drill/melt a suuuuper tiny hole in the top that will bleed the pressure as I drive
			Rotopax Review
Original Writeup:
