cozdude
Guy with a Red 2-Door
Thank you, I thought I saw 40's on one of your videos.
JT
moby (white 4 door) is on 40's and rubicat (orange 4 door) is on 37's
JT
I'm having my 5.13's done in 2 weeks for my 2014 with 37's and auto. What speeds are you all traveling at on the interstates? Some of our speed limits are 75mph so I've heard from local shops that 5.13's will get too hot. Thoughts?
On the 5.13 gears, how many teeth are actually engaged?
I remember one shop saying the 5.13 only had a few teeth engaged and more likely to snap a tooth than 4.88.
Any truth to that?
Thanks again, you all have been very helpful.
Very much appreciated!
JT
For a D30 that is the case. D44 has a bigger ring gear so it does fine.
Is there any compelling circumstance or reason that you would ever recommend 4.88 on 37's?
cozdude said:moby (white 4 door) is on 40's and rubicat (orange 4 door) is on 37's
At 75-80 MPH, I run about 3000-3200 RPM with my 37's and 5.13's. That's about 500 more RPM than if I were running 4.88's.
Any issues really running those RPMs? That just seems really high. I know you have done it a lot longer than me cause mine is still stock, that's why I ask. My plan is someday to go to 37s and drive it wherever I want like you all do with Rubicat and Moby.
Only issues you'll see is bad mpg on the highway at high speeds.
If there is a downside, it'll be that you won't get as good of MPG when driving 75+ on the highway. If you can keep the speedo at about 55-65, the difference won't be much at all.
What Adam said. A Dana 30 has a smaller ring and pinion and at 5.13's, the pinion gets to be really small and will leave you with about one and a half teeth making actual contact with the ring gear. A Dana 44 has a larger ring and pinion and you won't see this problem until you get up to a 5.38.
On a 2007-11 JK with a 3.8L motor, the ratio you want with 37's is 5.13. On a 2012-up with a 3.6L motor, 4.88 will get you back up to stock performance but, I personally would still recommend 5.13. Where I would recommend a 4.88 is if you're trying to run 37's on a Dana 30. At that point, a 5.13 will leave you with a pinion that is very small and will be a weak point. In this situation, strength of your gears should trump your desire for more power.
What cozdude said. :yup:
For what it's worth, on my JKU Sport AUTOMATIC, I installed 4.88's when I installed 37's. This was about 800miles ago.
When I saw the tiny pinion size of my4.88's, I couldn't imagine anything lower going in to the D30. :shock:
I'm very happy with the setup. Speed limit on the freeway in my area is 70, but I find that if I exceed 65, my mpg drops about 2mpg. Vader's happy at about 60mph. This past weekend, I averaged 17.2 mpg over an 85mile trip on the freeway with a few light grades.
For what I do with the family, 4Lo works great with this gearing.
Are you having a shop install everything or DIY?
Wayalife : "Where I would recommend a 4.88 is if you're trying to run 37's on a Dana 30. At that point, a 5.13 will leave you with a pinion that is very small and will be a weak point. In this situation, strength of your gears should trump your desire for more power."
Ok,
I'm really sold on the idea of the 5.13 for power but:
I'm concerned about the 5.13 since I still have the stock Dana 30 Solid Front Axle, and will have the stock axels for quite a few years.
I'm adding a full Artec Truss kit front & rear.
I need this to be bullet proof with no worries the first time around.
So it may have to be 4.88's?
Food for thought, here is a list of equipment that is being installed, the 4.88 gears that is listed is there as a place holder while I decide on the actual gears.
Yukon D30 Short Reverse 4:88 Ring & Pinion, Front JK 24 Spline
Yukon USA Standars D30 Front Install Kit JK
TEN Factory Front Axle Tube Seals For 84-14 Jeep® Vehicles with 30 Spline Dana 30/44 Front Axle
Yukon 4340 Chrome-Moly Axle Kit for Dana 30 Front, Non-Rubicon JK,
ARB Air Locker Dana 30 27 Spline 3.73-Up
USA Standard replacement Ring & Pinion gear set for Dana 44 JK rear in a 4.88 ratio
USA Standard Master Overhaul Kit for the Dana 44 JK non-Rubicon
Rear Differential
ARB Air Locker For D44
Yukon 4340 Chrome-Moly replacement rear axle for
Dana 44, 30 spline
SET10 Axle Bearing & Seal Kit for D44 & M20
ARB High Output OnBoard Air Compressor
Synergy Suspension Air Compressor Bracket
Amsoil Severe Gear Synthetic EP- 75W -140
Your thoughts (again)?
And thanks again for your time and advice.
JT
I know we all have budgets, but at this point, why not stretch it out and get the pro-rock 44? $2700 well invested, and you could probably get it out-fitted as a package with most of these items and drop 1 or 2 and save a few bucks and be truly closer to bullet proof.
