I would need ring and pinions along with install kit for front and rear correct?
yea a master overhaul kit should have all the bearings and shims needed.
do you plan on doing the install yourself? if not see if you can find a shop that knows gears and can order all parts for you so you dont order something you dont need by accident.
A friend of mine has done them on his Dodge Hemi and several other vehicles. Thinking about letting him do them. Still up in the air tho.
ahh ok. well if he does your going to want a master overhaul kit like this for the front and rear (one provided is for the rear)
http://www.northridge4x4.com/drivet...-non-rubicon-dana-44-rear-master-overhaul-kit
and new R&P gear ratio of your choice. as wayalife metioned all of them are made by the same company in korea so just look for the cheapest set.
(gears provided are just for price reference)
http://www.northridge4x4.com/drivet...gear-set-dana-spicer-44-jk-rubicon-4-88-ratio
If you don't change the front gears on the axle, to drive around do you need to take off front driveshaft? Or just not engage 4wd
Thanks man! I appreciate your help!
your welcome. here is a master overhaul kit w/ gears included to look at as well.
http://www.quadratec.com/products/52440_041X_PG.htm
Northridge has a package deal a lot cheaper than quadratec here's the link
http://www.northridge4x4.com/northr...n-30-44-gear-package-and-master-overhaul-kits
Do you guys think I should start with a programmer before I do gears? Been looking at Diablo and superchips.
No. Well, yes technically. You CAN do that, but then you can't put it in 4wd or you'll blow up your transfer case. So the real answer is no you can't. The front and rear outputs of the task need to spin at the same rate or else it will catastrophically fail quite quickly.
With the 3.8 engine and 35's with auto, you want to go with the 5.13 Ratio.
If you are running a manual, then the 4.88 Ratio!:thumb:
While you can get away with it its very risky especially on that dana 30. That pinion will be really small and as it is the ring and pinion is normally the weakest link in the dana 30 being that it is so small compared the the dana 44. I'd personally stick with the 4.88s because but that's just me :yup:
