LOL - he sells plenty of things to people who need what he has to offer.But ole Mel needs the money.....
3.5" is a standard for a reason. Can't really go wrong with it.This original post helped me make a decision on going from 3.5" backspace with 37s to 4.5" backspace.![]()
Question: your original post shows 4.75" backspace with 37x13.50 tires. I'm moving to the 4.5" backspace because the wheel I want (Icon Rebound Pro beadlock) is only available with that backspace. Do you think there will be an interference issue on my JLUR with a 3.5" Metalcloak Game Changer?3.5" is a standard for a reason. Can't really go wrong with it.
Hard to say for sure but with the 13.50's, I definitely had rubbing issue with the coilovers I was running.Question: your original post shows 4.75" backspace with 37x13.50 tires. I'm moving to the 4.5" backspace because the wheel I want (Icon Rebound Pro beadlock) is only available with that backspace. Do you think there will be an interference issue on my JLUR with a 3.5" Metalcloak Game Changer?
In checking my current 37x12.50s on 3.5" bs, it appears I have enough clearance for the 4.5", I may have to deal with some front liner rub at full lock-full flex.Hard to say for sure but with the 13.50's, I definitely had rubbing issue with the coilovers I was running.
With 12.50's, I would think you should be fine. The 13.50's and the greater BS is what was giving us problems and enough so that we had to run wheel spacers. Once we moved back to 12.50, things were better and better still with new wheels with 3.5". Things to check are the rear sway bar links. The ends that mount to the sway bar can dig into the sidewalls especially if you have really big droop. Up front the problem would be with rubbing things like bypass shocks or coilovers but you don't have them so you should be okay.In checking my current 37x12.50s on 3.5" bs, it appears I have enough clearance for the 4.5", I may have to deal with some front liner rub at full lock-full flex.
