OllllO Fanatic
I have not upgraded them. My plan was to buy RCV's and put them in the Jeep until needed.
If you are going that route then ignore me!![]()
You ever figure out what was making that bang sound? I was doing some more research about coil overs and saw some people mentioning it could be the coils slapping the shocks. They added spacers and that seemed to help. Not sure if that is the cause on yours tho.....
I talked to EVO and they told me to adjust the 2 silver rings in the middle of the upper spring, all the way down. They believe this should eliminate the bang. If not they recommended stiffer springs in the rear.
On a different note I am doing the diff oil change after break in and am finding the rear diff will only take 1 quart, and the front won't even take a full quart. Do I need to jack up one side to get the proper amount in? Both fill holes are not at the middle of the axle. And both axles are stock diff covered 44's. Thanks for your help in advance.
I am still trying to figure out where I found the first thread (maybe someone else can chime in - thoughts it had to do with JAGs but could be wrong) but after looking up a couple other I see what you are referring to and that sounds like it should fix the problem....Page 6-7 is where is talks about the noise of the coilovers and the spacers but I think if you just adjust the silver timing rings as EVO mentioned you should be good.....
http://wayalife.com/showthread.php?3612-Evo-bolt-on-coilover-install/page6
I'm new to this forum and certainly dont want to come off like a know-it-all,, but I do run CO's. First,, you might want to get the composite sliders from King. they have a longer skirt and may help stop or reduce the spring from slapping the body of the shock. Secondly, have you checked to see if the noise could be the spring hitting the track bar? last thing to consider is you have a very heavy spare tire/rim, and rear bumper and although the bumper is a little closer ,, I'm guessing the tire is about 3ft behind the rear axle(because thats where mine was). Thats a lot of weight on a long fulcrum. Stiffer springs might be the answer. Good luck figuring it out:thumb:
PS. Nice Jeep!!
If your spring isn't close to your track bar,, it wont hit. With where I relocated mine,, it rubs just a little.
