DA RUNT
Someone seems very interested in an anvil 10A build .....
Just trying to get ideas for yours :brows:
The build starts now..
Stock
EVO MFG 1.5" Leveling Kit. HD swaybar links installed
Best headlights on the market Trucklites!
Trasharoo!
ARB frig! View attachment 34315
It's now ready for Overlanding
Since it was just a leveling kit, wouldn't surprise me if they ran the factory monotube Rubicon shocks
Sent from my LG-D800 using WAYALIFE mobile app
I'm curious because I would like to run Bilstein 5100s.
You can do that. Bilstein and most of the other shock manufacturers make a 1-3" lift shock for the jk. Just add some 2" bumpstops and either new brake lines or drop brackets. If you have a 2012 plus, you might need exhaust spacers.
Gotcha. Thanks for your input.. How much do some bump stops run?
You can get some for under $100 for a full set of front and rear. The evo kit may come with some, I would check or call.
If your not gonna wheel the rig I think a couple shock manufacturers have 0-2" lift shocks, so you could always get those and not need bumpstops with 33" tires and below.
I plan on doing a little overlanding and trailing, only tiny rocks though. And I'll be running stock BFG and rubi wheels.
In that case, you can get the 0-2" variant and not need bumpstops, unless the leveling kit comes with some, and be good. Even if you decide to go to 33's down the road you'll still be fine (only minor rubbing on 33's at max articulation) :beer:
I was told the 0-2 wouldn't work for the 2 inch front coil set-up
The kit doesn't have bumpstops, not sure why you wouldn't just use your existing shocks with it- it comes with 2" front coils and a 3/4" rear spacer. The only other thing you really need is a little bit longer sway bar links in the front- a set of jk rear links will work in the front.
With us doing the level ourselves, I found it a good opportunity to get some great shocks on board whether I needed them or not. And.. Good excuse for the girlfriendhaha
My concern is only for the rear, since we are only lifting 3/4s of an inch. And I didn't know I needed a new sway bar link, the guys at Northridge said I'd be fine without em.
Saw this today. Love this jeep! Does it have a front drive shaft?
Did you read the one guy's post below that pic? Kind of comical, I don't think he knew who the owner of EVOlander is.
Lmao, was it the nitto tires suck post? Poor Mel gets to many trolls.
