desertrunner
I just did these like 2 weeks ago on my 2 door and this is my second set. This round went WAY better than my last one so I'll share what I did.
Use some Irwin quick grip clamps (or similar) to clamp them up to mark holes, when you mark the holes make sure you push the body armor up to the body if it's not touching before you mark the hole. A few spots on mine were like 1" away from the body so we by hand squeezed it up there like it will sit when it's tight to mark the holes if that makes sence. I then used a punch to get a good mark for the drill bit. I didn't use any smaller bits just went straight for the 3/8" bit which is a hair smaller than the diameter of the nutsert so you may need to do a few in and outs with the drill bit to get the whole slightly bigger. Also some of the holes have to go through more than just the first layer of sheet metal, some of the metal on the edges and the bottom are really close together and the nutsert won't fit in far enough to get clamped down. With that in mind try not to wreck the first hole drilling the second deeper hole (so to speak). I then used some touch up paint to paint the holes. Put a dab of red lock tight on the nutserts and used that same Astro tool to clamp them. And as mentioned practice it once or twice as it is strong enough to really jack those things up. I let the lock tight dry for like 30 mins then bolted them up and they fit pretty damn good (a hell of a lot better than my 1st set that ended up with a few popped rivets that spun with the bolt half way out due to the holes not lining up right)
