mikefishes
I recently bought a set of the rear d-ring mounts that bolt in to the factory frame rails. The instructions indicate that you "may" trim the rails for a flush fit. Before I went that far I decided to test fit them without trimming. The tot of the EVO piece will not fit within the frame rails at all. I am a little hesitant to trim the rails for fear that I am doing something incorrectly.
The question is... Does anyone here know if the frames are a bit wider if you trim up, or is this a job for the BFH?
