EVO long arm, Weld or Bolt?
Wait i thought those were just extensions of the sliders. Rub down a rock from slider, drop down to the rear control arm and hop up on it with rear tire. 🤔
Yes. We didn’t use all the bolts as if it were bolt on. Just enough to hold it in place to weld. Does that answer your question?
Haha, sort of. I’m sure it’ll make sense when I go to install. There’s 4 bolts that hold it on right? Looks like you left at least one out. 2 that go through the crossmember and one you have to drill the frame for?
Wait i thought those were just extensions of the sliders. Rub down a rock from slider, drop down to the rear control arm and hop up on it with rear tire. [emoji848]
I like that spin on it. [emoji23]
Anyone know if the EVO high clearance brackets can be adapted to a stock D44? I imagine the question has come up ...
Evo High Clearance long arms with coils and shocks? Check ✔️
Evo High clearance long arms with bolt on coil overs? Check ✔️
Evo high clearance long arms with bolt on coil overs fixed and made to work better by Exodus Jeeps? Check ✔️
It’s all possible, you just have to think outside the packaged box!
And have a welder. [emoji23]
Thanks! That’d be the route I’d go if I go long arms.
In the next few days EVO MFG will offer a High Clearance Long Arm that you can run coilovers or a coil spring for the Jeep JK. We will also offer a retro-fit kit for customers running the EVO-1085 Double D rear brackets. :rock:
Feel free to call in at 714-879-8913 or email sales@evomfg.com for more details :thumb:
Robert @ EVO MFG
Robert @ EVO MFG
Now that is interesting news. Is there a P/N?
