Oh, other joints would include Clevite bonded rubber bushings. They can be found on stock control arms and on a lot of aftermarket companies like to use them for frame side joints. Doing a test on them at Off Road Evolution, we found them to be surprisingly resilient and durable. Sure, they had bound up when flexing but, not enough to limit big travel. If there is a down side to them it's that big flex will cause them to blow out prematurely.
Another joint would be an FK rod end and they are what Full Traction uses. This is an amazingly strong and bind free joint. NO joint can compare to the amount of rotation this joint or its equivalent, a uniball can provide. Because they are essentially metal to metal, there is ZERO absorption of road noise but, having tested them out on my JK, I can tell you that you really can't feel that much of a difference.
