black pearl
I plan on using the CB mount, but need to get a spring to help protect the antennae. I am not sure if you have a lot of experience with the outserts, but recommend buying an Astro 1442 tool.
When using it, I found that you need to feel when the nutsert is correctly set. After compressing the nutsert the first time, I screw the tool deeper on the nutsert and compress it a second time until it feels tight. If you go too far it will deform the bottom of the nutsert. If you do not tighten it enough it will spin. After setting the nutsert, I go back with a tap and chase the threads, then use anti-seize on the bolts to ensure they do not seize over time.
I actually have a nutsert tool on the way.
Curious on how your running the antenna cable, with the corners.
