Enforcers Unite!
Are lower shock relocation brackets necessary for the 9000XL shocks?
I don't think they are totally necessary unless you really start to wheel and flex-out on the trail. I read a few different posts about how the top of the shock body will contact the frame when fully articulated. IMG_7561.jpgI'm running front-lower shock relocation brackets. The compressed side of the suspension is fine with plenty of shockbody clearance. IMG_7572.jpgIMG_7581.jpgThe decompressed side is a different story. You can see how close the top of the shock body is to the frame. Without shock-relo brackets, they'd be even closer to contacting the frame.
I needed them for my setup. The body of the shock will hit the frame at full droop. I didn't want to take the chance of the shock bending or breaking. Take a look at your shock, if you see paint rubbing you need them. Or cycle your suspension and take a look.
Hey all, looking to install the 3" enforcer on my 2013 2 door. I am planning to go with rancho 9000s for the shocks just not sure what size to go with. Any suggestions?
Any Enforcer fans running the Fox 2.0 reservoir with adjusters? Looking for other options besides the Kings and Rancho 9000's. Who will be the first to throw a set of Teraflex Falcons on! Thanks,
I'm considering the 3" enforcer but was wondering if anyone has put this lift kit on a 2.8 crd or if anyone here might know if the added weight of diesel engine might cause issues with these coils?
Sent from my SM-N920C using WAYALIFE mobile app
ok so i know i've asked this before but i'm wanting to put on an enforcer lift but not sure what lift. i'm going to run 37s after my 35s and i know a lot of guys run a 3 inch just fine but wanting to know would i need to upgrade any other parts with a 3 inch lift? i know i would with a 4 inch. also i mostly wheel with a full jeep meaning passengers and gear plus with my winch bumpers and tire carrier i get some sag so what would be the best lift for JKU with 37s and flat fenders? 3" or 4"??
I would definitely run 4" if your going to wheel...seems like rub would be an issue with a 3...here is my JKU on 37s with a 4" IMG_0561.jpgIMG_0565.jpgIMG_0594.jpg
