TrainWreck618
Looks great! Time to play
Also here's my list of my lift if anyone would chime in to help make sure I'm not missing anything, would be much appreciated.
Enforcer 4" lift kit / with plush springs, Evo drag link flip, Evo c gussets, Adams front drive shaft, rancho 9000's, Evo front shock relocation brackets, and the Evo rock stars. This is my first lift just trying to make sure I have everything all in line and some noleage before I order/ install everything. Sounds like this lift is the way to go!
Even better you could find a used rubi swaybar and outfit it with the EVO nolimits disconnect. Some of the best money i ever spent on my "non-rubi"Awesome thanks for the input. Non rubi so I look into some quick discos.
How many of you are running 3" Enforcer with aftermarket rear driveshaft and stock rear arms? Any issues with pinion angle and vibes?
I have the 4 inch. Your main concern would be the front driveshaft as the boot gets melted/ripped off by the exhaust
I just put 3" in with the 9000's and Rockstars. Used 330/331 per Rancho recommendations. Seem to work, but not flex tested yet. Check my build thread. Or even better contact Rancho thru this great site.
Sent from my iPhone using WAYALIFE mobile appView attachment 238358
You should flip the rear shocks around so the adjustment knob faces inwards. Yes, more of a pain to get to and adjust...but otherwise you're asking to snap it off when wheeling.
Snap! You're right. Thanks. I need to post up my build - I am sure there are a half dozen recommendations like that. At least!!!
Start a build thread!
Your rig looks really sharp on the stock Rubi wheels still!
So, if you don't use the drag link flip, do you need an adjustable track bar?
Not to come off like an asshole, but i would HIGHLY recommend installing a drag link flip kit. If you dont, your going to experience massive bumpsteer. Ask me how i know. I ran mine without the draglink flip for a week because i had ran out of time the weekend before and had to get to work that week. I can recall times going 70 down the highway and hitting a seemingly small pothole and swerving a lane over. And theres nothing you can do to stop it. Please for your personal saftey alone, install a DL flip kit. $300 is not worth white knuckling it down the highway.
