CalSgt
That’s my understanding tooWhat do you define as Thrust angle? I thought that was the rear axle being perpendicular to the centerline of the vehicle.
That's quite a personal question. We all have our own tricks.What do you define as Thrust angle?
I’m guessing he means the rotation at acceleration.That’s my understanding too
You are right, my misuse of the term. What I'm actually referring to is the angle from the diff (pinion) to the driveline which is pinion angle. I'll go back and correct my posts. Thanks for pointing that out.What do you define as Thrust angle? I thought that was the rear axle being perpendicular to the centerline of the vehicle.
1-3 degrees seems to be the norm for most vehicles, but i'm pretty sure that doesn't account for lifted vehicles with large amounts of travel. My particular lift manufacturer actually recommended -1 degree to compensate for added flex and additional weight in the vehicle. When I called them to verify this they said anything between -2 and +2 is a good range. I think you are pretty good where you are at, every time you get in your vehicle or throw anything in the back that angle is going to change a bit. Pinion angle isn't static under use, It's all about not hitting an angle where binding or excess wear and tear happening when the axle is moving up and down.I believe my pinion angle is .5 degrees higher than my driveshaft. I've been told it should be at zero and I've also been told it should be 1-2 degrees lower![]()
You're best option is to verify the yokes are running true. Even a slight out of roundness as the drive shaft spins on either end will cause a bad vibration.So I'm guessing my last options here are to look into the T-case and pinion flanges? Bad gear setup? It didn't vibrate when I ran it with just the front shaft, but then again the rear diff was not under load.
A dial gauge will definitely help. But if you don't have one, spinning the drive shaft as I mentioned in my earlier post is a quick and easy way to verify the DS is spinning true. If you notice any up and down movement as the DS spins, that's the source of the vibration.A dial Gauge should help...
Yes, the statement that the uppers are for angle and the lowers are for wheel base only goes so far. It can always end up being a balance between the two.can lengthening of the lower CAs help lower the pinion angle? I know it’s supposed to just push the axle back, but I feel like it may also bring the pinion down?
