Draconianwinter,
Are you putting all your new parts on soon ? Look forward to seeing it.
I have grown a liking to Poison Spyder for their products and service. I just wanted to make sure I was not buying Chinese made items. Although I don't live in the USA I am next door and support anything made in either country.
I'm not quite as concerned about the steel, I just want to at least see them getting designed and built on our continent.
It's hard to avoid this stuff these days.. Even buying clothing is difficult as most is made in China with an American name in it.
Nice! I am like you, adding parts slowly to the build. The catch is I have no Jeep to drive in the meantime. Check out my build thread, you will see why lol.
So trying to cum up with a name for the jeep. Seriously thinking venom as I will be putting nearly all poison spyder on it. The rocker gaurds the bumpers and going to include differential covers a well
That's a great name
so one thing that is both a curse and a good thing is that we have so many choices for our builds. mine has changed directions already more than once.. so I currently have on order the evo leveling system. will be putting that on when I get back into town as it should be here by then. will also be ordering the mopar high top fenders and will then be going to a 35 inch tire. at some point I may change it to a 2.5 inch lift with the 35s just to give it more underside clearance. for now that is all I have, and also chose the name, and her name name is silver dollar.
Being that you have a two door, I would go ahead and buy a set of 1.5" rear spacers. The 0.75" that comes with the leveling kit is not enough for the 2dr in my personal opinion and you will be riding nose high.
Good news is that running this setup, you will be able to run 35s without chopped or high line fenders. You're going to get a little over 2" of lift in the front with the springs already. To me, the perfect, cost effective setup for a 2dr is the front 2" plush ride, rear 1.5" spacer (or 2" OME springs), cut factory flares, and 37s!
Nice. thanks for the info. I will make sure I look into the higher spacer or even the ome spring. now will the springs cause me to need a track bar relocation brackets to keep the axles centered properly?
