Thanks for the reply, it has 85000 miles on it, I use Mobil 1 synthetic oil, but not high mileage, I did an oil change 1000 miles agohow many miles are on it? sounds a bit like my 3.8 until I begin to use high mileage synthetic.
Thank you so much, that is exactly the type of video I was looking for. The ticking is so pronounced, mine is not like that. My neighbor that is a car guy did not hear ticking. Mine does not sound anywhere near that bad.Could you post a couple more videos of it? Maybe from either wheel well? I feel your fuel injectors might be muddying up the possible ticking noise.
Here is what mine sounded like just before I got my rocker arms fixed.
Fuel injectors or something else ticking? 2
youtube.com
youtube.com
it's pretty consistent.Is it worse on a cold start, does it get quieter at higher rpm or on a longer drive?
Before your next oil change run some seafoam or marvel mystery in the oil, see if a quick clean 100 miles or so helps it at all. It doesn't sound damaging or anything super bad, but there's definitely noise. Wont hurt to run the cleaner through with some gas as well if you suspect injectors are dirty.it's pretty consistent.
thank youBefore your next oil change run some seafoam or marvel mystery in the oil, see if a quick clean 100 miles or so helps it at all. It doesn't sound damaging or anything super bad, but there's definitely noise. Wont hurt to run the cleaner through with some gas as well if you suspect injectors are dirty.
thank youWhat snboarder113 says. Also, if you begin to hear a more pronounced ticking like mine, do not take your time getting the rocker arms replaced. If I had waited longer, the mechanic said I would’ve needed the camshaft replaced and that is not cheap.
