1st thing I would do is get the tires rebalanced, I've had weights fall off; it happens.Okay, so I had some time to get under the jeep this weekend and didn't find a single joint with any play. I had my son saw the steering wheel back and forth and didn't find any of the steering or suspension components moving at their connection points.
However I did feel a bit of crunch or cluck in the drag link. I could feel it when I grabbed the link while my son was moving the wheel with the engine on. The drag link joints did not seem to have any play in them, though. I checked the pitman arm and that also did not seem to be loose on the shaft (on the big end).
However, when I had him start the engine and saw the wheel, while looking down from the top of the engine bay, I could see the steering gear box moving side to side. Not a lot, but there is something flexing or the frame is cracked. I have a Rusty's frame side trackbar brace and the bolts that go through the frame are tight and don't move at all while he is sawing the wheel.
I also observed a small amount of play in what I believe is the driver's side unit bearing.
Third thing I found was zero weights on the front driver's side wheel. But there is some adhesive on it. But I'm not sure that was left overs from when I had the Milestars pulled off and put the new Falkens on.
I had a friend show up just as I found these three things and haven't been able to investigate further.
But I think I still have my stock track bar (not sure) but if I do I am going to put that in to see if anything changes. Before I do that though I am going to do a 4 tire rotation to see if that wheel with no weights is involved.
Disciple is a 5 hour 30 minute drive from my house at freeway speeds. At this point I can't go over 45 MPH safely.I’d try this:
If you have a way to tow it I’d go see Jeremy at disciple. 4wheel parts in AZ blowsDisciple is a 5 hour 30 minute drive from my house at freeway speeds. At this point I can't go over 45 MPH safely.
I know how to search google maps. But what I don't know is which one of the 3 or 4 4WD shops in Reno have a good or bad reputation. That's all I'm asking for is recommendations. There is a 4 wheel parts store in Reno, but have no idea if they can be trusted to do anything except throw parts at it.
Pretty much every four wheel parts blows, their business is selling parts, not fixing thingsIf you have a way to tow it I’d go see Jeremy at disciple. 4wheel parts in AZ blows
My checklist to find the issue would beOkay, so I had some time to get under the jeep this weekend and didn't find a single joint with any play. I had my son saw the steering wheel back and forth and didn't find any of the steering or suspension components moving at their connection points.
Item #1 is next. #2 already done. When I installed the rusty's frame-side trackbar brace I torqued and red loc-tited. I also marked to bolts with a paint pen so I could see if they moved. While under there last weekend, I checked if they were tight and I couldn't move them. Also the JL frame is known to flex, it turns out. I also have to get back in there and see if the frame is cracked. RE #3, I didn't feel any movement in the trackbar joints. The only thing I could feel something odd on was the drag link/pitman arm/steering box as mentioned above. #4 I didn't think would be a problem since the ss is only 6 months old, but I'll try that today. As far as moving parallel, I have a metalcloak tie rod and their mounting brackets on both the axle and tie rod. So, the ss i at a slight downward angle from the axle to the tie rod. Both mounts are made with an angle in the mounting surface to prevent binding. But I'll check that again.My checklist to find the issue would be
1. Have all tires rebalanced,, but then again I buy from Discount Tire and don't have to pay for these things no matter how many times they get rebalanced.
2. Check the torque on the steering box with a torque wrench. if it's moving something is allowing it to flex.
I always loosen the bolt to make sure something isn't cross threaded, add red thread locker and torque to spec.
3. If you felt track bar issues the only way to fully inspect this to remove it and see if the bushings are shot.
4. Steering stabilizer, I'd pull it off, check the bushings, put it back on and make sure it's moving in parallel with the tie rod full lock to lock. If there's any binding in the steering stabilizer it will cause anything from steering kick back to possible DW.
learned my lesson years ago, don't trust just a visual inspection and me shaking a parts to see if it's tight.
At the torque values these items should be at, they would have to loosen up quite a bit to be able to manually shake check it for looseness.
. Anything with a bushing I will always remove and check the bushing if I suspect there is an issue with that part.
Now days it’s tough to find a competent shop. I’ve heard horror story after story of rigs coming back worse than they went in.Jeremy is a good dude and a friend but I think even he would agree that towing your Jeep 5+ hours to him for death wobble is a bit excessive.
