My Amsoil fluid shipment arrived today
Engine Oil (Filter) • Absolute Efficiency Oil Filter (EA15K51-EA)
Engine Oil (fluid) • Synthetic 5W20 SS Motor Oil (ALM1G-EA )
Transmission (fluid) • Synthetic 5W30 Manual Trans (MTFQT-EA)
Engine (flush) • Engine & Transmission Flush (FLSHCN-EA)
Diff/Gear (fluid) • Synthetic 75W110 Gear Lube (SVTQT-EA)
Transfer Case (fluid) • Synthetic Multi-Vehicle SS ATF (ATFQT-EA)
Fuel Additive (Injector Cleaner) • ORMD Quick Shot Fuel Additive (AQSCN-EA)
Brakes (fluid) • Amsoil Series 600 DOT 4 Racing Brake Fluid (BF4SN-EA)
Here's more information for those that are interested:
LUBRICANTS & FLUIDS:
Engine Oil Grade 1......API*
Maximum Performance SAE 5W-20 Signature Series 100% Synthetic Motor Oil (ALMQT)
Performance Plus XL 5W-20 Synthetic Motor Oil (XLMQT)
Performance OE 5W20 Synthetic Motor Oil (OEMQT)
Manual Transmission,NSG370 (6-SPD)......GLS [1]
Synthetic Synchromesh Transmission Fluid (5W-30) (MTFQT)
Automatic Transmission,42RLE......AP4
-------Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
-------OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Differential, Rear W/ 198 RBI W/O TT......GL-5
---All TEMPS......80W-90 [2]
------SAE 80W-90 Synthetic Gear Lube (AGLQT)
------SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
------75W-90 Synthetic Long Life Gear Lube (FGRQT)
------SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Differential, Rear W/ 226 RBI W/O TT......GL-5
Differential, Rear W/ 198 RBI W/ TT......GL-5
---All TEMPS......75W-140 [2] [3]
------SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
------80W-140 Synthetic Long Life Gear Lube (FGO05)
Differential, Rear W/ 226 RBI W/ TT......GL-5
Differential, Front W/ 186 FBI......GL-5
Differential, Front W/ 216 FBI......GL-5
Transfer Case,NV241......AP4
Steering/Brake Fluids
---Power Steering Fluid......AP4
------OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [4]
---Brake Fluid......HB
------AMSOIL Brake Fluid DOT-3 (BF3SN) [5]
[1] Mopar part no. 04874464 or equivalent
[2] Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR Limited Slip Additive
[3] Synthetic based oil.
[4] ATF+4® Automatic Transmission Fluid
[5] Hydraulic Brake Fluid, DOT 3
P/N 04318080AB or 04318081AB, meeting MS-4574
FILTERS:
Oil Filter--Absolute Efficiency Oil Filter (EA15K51) [1]
Oil Filter--WIX 51348 Oil Filter [2]
[1] Replaces the Ea15k33, which will still work for this vehicle
[2] Spin-on Filter
NGK PLUGS AND WIRESETS:
GPSERIES PLUG ----------------- LZTR5AGP
IXIRIDIUM PLUG ----------------- LZTR5AIX-13
PREMIUM PLATINUM PLUG ------ PLZTR5A-13
VPOWER PLUG ------------------- LZTR5A-13
WIRESET ------------------------- RC-CRX067
WIPER BLADES:
Blade Class------Driver____Passenger____Rear
ExactFit T151 T151 T12E
NeoForm T16140 T16140
Winter T37150 T37150
CHASSIS LUBRICATION:
4WD
5-20 Fittings, 0 Plugs..........LM
RWD
7-8 Fittings, 0 Plugs..........LM
CAPACITIES:
Engine, with filter.....................................................6 quarts [1]
Cooling System, Initial Fill.........................................12.7 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 42RLE Initial Fill....................4 quarts
Automatic Transmission, Total Fill 4 speed 42RLE.........8.8 quarts
Manual Transmission, NSG370 (6-SPD).......................3.2 pints
Differential, With 198 RBI With T Rear.........................3.8 pints
Differential, With 226 RBI With T Rear.........................4.6 pints
Differential, With 186 FBI Front..................................2.1 pints
Differential, With 216 FBI Front..................................2.7 pints
Differential, With 198 RBI W/O Rear............................3.8 pints
Differential, With 226 RBI W/O Rear............................4.6 pints
Transfer Case, NV241................................................4.2 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....20 ft/lbs
Manual Transmission
Fill Plug 22 ft/lbs
Drain Plug 22 ft/lbs
Transfer Case
Fill Plug 15-25 ft/lbs
Drain Plug 15-25 ft/lbs
Sent from my NSA monitoring device... Using the WAYALIFE mobile app
