Spudcannons
Not sure who you're asking but if you're asking me you can see my cordless stuff on post #29
A list of what you would consider essential/helpful tools for working on a wrangler.
You talking cordless/power tools, or tools in general?
All of it. :yup:
I would say a basic hand tool kit will cover quite a bit. The most recent tool that I've added was a new ball joint press.
Kind of a tough question to ask. But if you're wanting a better break down of what a standard hand tool kit is...I'll do my best to write up a list plus additional items. I'm sure I'll forget a few things!
Absolute necessity is 12pt and 6pt metric and SAE 1/2", 3/8", 1/4" sockets (including torx/hex). Long and short handle ratchets. Breaker bars. 1/2" impact sockets. Extensions, swivels, and adapters. Air or cordless tools to drive all 3 sizes. Metric and SAE combination wrenches (I'd recommend additional ratchet wrenches). Line wrenches. Quality wire strippers and diagonal cutters. Soldering iron. Screw drivers, nut drivers, and torx drivers. Awl and pick set. Ball joint press. Pry bars. Brake caliper spreader and brake spoon. Quality digital multimeter. 12v test light. Ball peen hammer, small sledge hammer, dead blow hammer. Slide hammer set. Drill bit index. Sawsall. Angle grinder. Air hammer/chisel. Cut-off tools. Adjustable wrenches. Arc-joint, slip-joint, vice grip, and needle nose pliers. Fuel line disconnect tools. Trim/molding tools. Pitman arm puller. 3-jaw puller. 3/8 and 1/2 torque wrench.
I have this same kit. Bought it while trying to replace ball joints on a 900HP 5.9 Cummins diesel which destroys ball joints and cheap press kits. No stripped threads...love it!!
Ordered yesterday arrived today. $100 cheaper than anywhere on Amazon. Thing is a beast. Thanks for the heads up. View attachment 116989View attachment 116991
That was through the Zoro sale?
Russ, do you happen to have the model/kit number on this? I'm hoping Zoro throws out a 30% off around 4th of July and want to be prepared to snag one when it comes up. Thanks
