AZ Explorer
Boots!
The old shifter boots are obviously old and somewhat poor condition based purely on age. I wanted to get something a little nicer and since I put on the 1 inch body lift, the levers don't line up with the holes as good as they used to.
I moved the cover plate back so it worked enough to function, but I'm not happy with it. Where the front of the plate meets the body, there's almost no overlap and I'd really like it to be right.
So I'm going to get a blank cover plate and cut the holes in the proper location. Also this will allow me to change the hole from round to square for the transmission.
The new trans boot is a Lokar with a billet trim ring. The transfer case boot is a custom order with a liner sewn in. I can get a 16 gauge trim ring for the transfer case boot as mine is bent up from over tightening (plus now it doesn't match). I have found a few machining companies locally that should be able to mill a billet ring to match the trans ring. It would be wider and different dimensions of course, but done in a similar style. If it ends up being too cost prohibitive, then I will order the steel ring which comes in black powder coat for $25.00 plus shipping.
After whatever I do to the body to finish it, I will at least carpet the front section and it should have a very clean look. This is another one of those detail things I am stockpiling as I go that will make the Jeep stand out some.
