Mine threw the P0520 code today. It's not on the list.
P0520 is the Oil Pressure Switch.
Just wondering if anyone knows the best way to put your Jeep through the drive cycle relearn to clear the "Not Ready" settings in the computer after changing the battery. I don't have any codes set, but 3 Not Ready's for Fuel System, O-2 Sensor and EVAP System.
Nope I have 08 3.8 manual and it works make sure your going to right spot with keyI've tried this several times with my 2011 JK and can't seem to get it to work.
Question... does this method only work with automatic transmissions?
I have a 3.8L 6 speed manual.
Thanks
Found a dealer to scan it for free with an OBD reader... evap code. Possible gas cap issue, but I don't think so. Anyhow, he cleared it and sent me on my merry way.
P0405 says egr position sensor low... has anyone else had this code and what was your fix... I'm gonna start with the wire harness and go from there really hoping I don't have to replace the egr valve itself ... I've been getting this code randomly about every other month sometime two months in between but no rough idle or stalling occurs any other symptoms I should look for
Dopey
