Cheap driveshaft?
Ive been looking at replacing the rear driveshaft with an aftermarket one and theres a few options. Should I go cheap with a rough country or spend a lot more or not bother upgrading it ever? Or does anyone have a good source on well priced driveshafts worth getting?
Yes I go offroad with it but nothing insane. Its a 2015 Jeep JKU with a 4in lift on 37 KO2.
I have to agree with cozdude ^^^ Nothing wrong with the factory rear shaft on a JKU. If yours is bent or dented from the rocks, look for a local shop and have them make a replacement u-joint style shaft for you. More times than not, it'll be cheaper and you can have them make it with components you want like 1350 Neapco joints.
I bought an Adams driveshaft for my Rubicon and I'm very happy with it. It has a good warranty. Trouble is, to have any work done under warranty means shipping it to Adams and back. Have a good local shop build your driveshaft
If you have a local shop im sure they could do the work for you if need be. Thats what I did with my JE Reel 1310 when I blew it up. Local shop fixed it good as new.
That’s true. However, having another shop work on the driveshaft will likely void the warranty
