Speedy_RCW
You mentioned checking continuity but have you checked for shorts between the shield and electrode in the coax?  You could get good continuity readings and still have an issue. Make sure you also check where you SHOULDN'T have continuity if that makes sense. As far as grounding the gate, I'm running the same CB and antenna mounted to my gate with no issues.
