How is everyone's reception with their antenna mounted on the spare tire carrier? My dad was nice enough to use his Pilot fuel points to get me a Cobra 19. He gave me one of his old Francis fiberglass antennas (basically a 3' Firestik) and an 18' coax. The spare tire mount is definitely where I want my antenna. It's the only location that looks good to me. I'll only be using the radio on the trail and close range on the highway.
I have good radio performance.
Have a solid ground, get the antenna high enough, then tune it with an SWR meter.
I am having trouble finding a local truck stop that can tune my cb radio. Does it make sense to buy a swr meter and do it myself? Are they cheap? Easy to do?
Thx
Thx
i would just try and find someone that has one that will let you borrow it or see if the truck shops will let you borrow one of theirs. prob the easiest and cheapest route to go.
Do you have one Steve? Maybe bring to suds n grub?
Thx
JKFlyer - white dotte is the best place around.
I'm about 95% done with my CB install, just need to pick up the SWR meter this weekend to do the final adjustments. It looks good on the 29LX I just want to be sure since everything I have seen so far say the built in meters get you close at best. What I have found on tuning so far is get it as close to 0 on 20 then 1 and 40 in an open area and all doors closed. Sounds simple enough but what happens if I decide to run doorless in bikini mode or full naked. Should I expect to have to re-tune the antenna based on running configuration?
If it makes you feel better army_vet I saw it another post and used it and it was very helpful. There is a lot of good info on the site. only beef is they need more pictures. yea im that guy haha
Your antenna length needs to be long enough to clear the top of your jeep by about 8-12 inches. This will give you the optimal distance forward to communicate. CB radios are good for line of site communication. Second a rule of thumb taught to me was CB coax should be in multiples of 6. It is what my pops taught me and I follow it today.
I have a 3ft fire stick I purchased in 2000 for a road trip that was just tuned and works great. If you have the opportunity go to a cb shop and talk to the techs. They will give you more knowledge than you ever wanted to know.
R/
Will
Sent from my fRuit product using WAL
Anyone have their antenna mounted directly to their tire carrier? By this, I mean drilling a hole in the carrier and mounting the antenna directly to it. I have the smittybilt/bestop carrier and I don't think the machined bolt on mounts will work. Plan on drilling a hole in the mount right behind the tire to mount the antenna. Just wasn't sure about grounding issues. Not to fond of drilling into the body to ground the antenna.
I have a mount on my tire carrier and it is grounded the ought the carrier which is mounted to the bumper that is
Mounted to the frame. One way to check is to do a continuity check from the bumper body. This will tell if your bumper is in fact a good ground. View attachment 71626
R/
Will
