SoCalDozer
the hammer in ones might not be to bad for me. and the locker thing doesnt matter because I dont want to lock the d30, I will wait til I eventually upgrade
You can't run EVO sleeves and an ARB locker. Not sure about other brands of sleeves.
Also one more thing since im only running 33's would just gussets be good? or do I need sleeves to? figured the c's were the main weak point
need a ball joint press tool and im not sure if the originals are reusable
I'm running ARB lockers and want to upgrade the front axles in my D30 next, so I should be looking for 35 spline front axles, would that be correct? Its already got gussets.An ARB front locker requires a 35 spline axle shaft. These won't fit in a sleeved Dana 44 Rubicon. EVO sleeve.
I haven't installed my 35s yet but with Dana 44s how long after I install can I wait until I put gussets on? Also sleeves. Did not put that into the budget.
It's a cheap mod to prevent an expensive fix. If you're not going to wheel much you may not need it but why take the chance?
I had little choice at that point. An electric jack hammer laying horizontally across a creeper seat, a 265lb man with his back into the jack hammer and feet braced against the wall pushing for all he is worth with his legs, another guy operating the jack hammer switches and still the sleeve won't budge the last inch (maybe half inch) and we were done. The sleeve stopped moving using an eight pound sledge hammer when it was half way in. I am guessing there was a weld or something half way down that tube that caused the issue.
This was not one of my proudest moments. :grayno:
I installed the pound in Nitro sleeves in my new Rubicon. Never have I been through such a monumental pain in the kiester! The long sleeve went right in as this is a brand new Jeep with no debris in the axles. The short side went in half way and would not budge. We ended up building a steel tool to pound on and rented an electric jack hammer to get it in there within an inch of the right depth. Ended up cutting off the last inch. We ran that jack hammer for an hour to get it in that far, never again. Once you get started you can't go back.
