HighwayTrout
Do you got two of the 6 inch ones?
Nope. Just these two
Thanks for trying.
Passenger and driver fire walls with the inner fenders off made it easy...er.
View attachment 357656View attachment 357657View attachment 357658
You can reach up behind the glove box and feel it. Thats how I found it then looked for it on the other side.Hell I’ve been wondering where that pass side firewall hole was for years haha
You're probably right!
Ok so I see PSC sells a bolt kit when you use the Synergy track bar brace with the big bore. But, what I can't find is do you replace the front left bolts only and reuse the factory bolts on the right?View attachment 357817
Yeah it did and specifically said to replace the front two bolts per PSC but apparently once you add the track bar brace you need to get longer bolts.You should be correct. When I installed my big bore in November it came with 2 new bolts for the one side.
Rockhard cage ordered 12/24 still waiting on shipping. This is aggravating.
I don't know how but I keep clipping my brake lines in the rear so Im moving them inboard. There was a hole that I just widen out in the shock perch and thinking of running it right through the perch. Does anybody see a problem with this?View attachment 357888View attachment 357889
Sweet. I couldn't remember who did that, thanks for the pictures. I ran a new line on driver side because I broke it twice. I was able to bend the passenger line to work the same way.That is exactly how I ran my rear lines, got these 90 fittings
