Brakes
GP NOIR
2 door 2012 Wrangler Rubicon w/manual trans
Who do we like for braided stainless steel brake lines? My brake lines are aging and I want to replace them.
I'm having trouble with the front right brake dragging enough that the Jeep bogs when starting from a stop and the brake runs a consistent 100 - 200 degrees (measured with a laser thermometer) hotter than the other three brakes. So far, I've replaced the front calipers, rotors and pads with the larger 13" JL brakes and replaced the master cylinder with a larger bore master cylinder. I've bled the brakes manually and with a scanner. The pedal is still soft and keeps going to the floor. Any ideas?
PS- I'm looking for a Mopar ABS module, but they are hard to find.
Have you checked and or greased your caliper bolts? Could be they're just dry and sticking. Back in the day, that was a normal step in brake maintenance.
Otherwise, I always thought the factory JK brakes with OE pads were plenty to get the job done up to 37" tires.
Have you check unit bearings? I had this happen when a unit bearing was going out. Needed 4wd just to go up a gravel road with a slight incline. The bearing gets toast and fries the sensor area because there is no grease.
I did not. Installed the new parts as they came. I forgot to mention the reason I replaced the brake parts in the first place is because the right front brake started dragging during a trip to Moab. Replaced the caliper with a standard replacement. It worked for a short time then went back to dragging. Had my Jeep towed home and have been struggling to get it figured out since.
Replaced both unit bearings and sensors. One unit bearing has a small amount of play and both tone rings were packed with red sand. Replaced both sets of ball joints. One set of ball joints were worn and I was starting to get the pre Death Wobble wobbles.
The proble/m may lie in leaaky or damaged brake lines.Con sider replacing them with new high-quality stainless steel braided hoses.Also make sure the brake caliper is _working properly and is not stuck;)
I’m planning to replace all four brake lines with braided stainless steel. That’s why I’ve asked who makes good lines in my first post.
Calipers on both sides are remans with less than ten miles on them. This is the second replacement caliper on the right side and the right side still drags. I do plan on checking the caliper guide pins for lubrication and freedom of movement as Eddie suggested.
I’m also going to get a new ABS module as soon as I can afford it. They ain’t cheap! Mine is cracked from being dropped.
Local pic-a-part yards may have ABS module?
I tried a junkyard module and had to return it. The hydraulic half leaked.
My thinking is if I have to go to the stealership and pay to have the module programed with the Jeep VIN, I want to start with a new module. However, if that's what I have to do to get my Jeep back on the road, I'll do it. Not being able to drive my Jeep is crazy making!
