Took it in to my local dealer and they put the laptop on it. No codes or anything so we scheduled it for an ABS bleed next Friday. They seem to think that will fix it.That sucks that it didn't fix it. Did you bench bleed the master cylinder first?
Some manufacturers have a way to isolate each part of the ABS hydraulic circuit of the HCU with a scan tool. I've tested them manually by plugging various parts of the brake system so you can find where the hydraulic pressure loss is but it's a time-consuming process. Along with that, it's such a rare failure that I haven't done it often. It should be covered under regular factory warranty if you're within the time and mileage. And you're 100% sure there's no fluid bubbling slightly at all bleeders and hose connections?
That sounds like a logical next step.Took it in to my local dealer and they put the laptop on it. No codes or anything so we scheduled it for an ABS bleed next Friday. They seem to think that will fix it.
Well, local Jeep shop did an ABS bleed and no change. They said the back calipers were bad. So on their advice I changed the rear calipers and again no changeThat sounds like a logical next step.
Tires don’t cause a spongy pedal. Pedal dropping to the floor with little pressure has not a single thing to do with tires.I have had a similar problem with my 2015 Rubicon JKU with 35" tires. Spongy Brakes. I I have bled them several times. Replaced the front pads, and have replaced master cylinders 3 times and still have spongy brakes. I was told by someone that the problem is the larger tires and the stock master cylinder that simply cannot handle it. Also, bake fluid would magically disappear which is why we changed master cylinders. My 4WD shop told me they thought it was going through the vacuum booster and vaporizing into the engine.
The pedal feels normal under typical braking but when you push hard on the pedal it will go to the floor when the engine is running. When the engine is off the pedal only moves a couple 3-4 inches. I am on a time crunch for our trip to Moab so I just ordered new braided brake lines hoping that will take care of it. I have thrown everything else at it LOL.Are they extra long? Is there a high point in which creates a loop / arch? Since we’re grasping at straws here if there’s an arch in the line a bubble can stay in it even while bleeding. Would need to remove caliper and straighten line to the lowest point you can and then bleed.
Are the extended lines extra long? Is there a high point in which creates a loop / arch? Since we’re grasping at straws here if there’s an arch in the line a bubble can stay in it even while bleeding. Would need to remove carpet straighten to the lowest point you can and then bleed.
When did you first notice the spongeyness. And to be clear the feel is a system with air in it, a pedal with little resistance, correct? Not just shitty braking performance. Have you had someone step on the pedal while you inspect any rubber lines for bulging?
even though you've done the bleed and it appears there is no air, the ABS must have some cavity that traps air but you won't notice it until you apply the brakes.Well, local Jeep shop did an ABS bleed and no change. They said the back calipers were bad. So on their advice I changed the rear calipers and again no change
so here is my question? I replaced my rubber brake lines with the EVO steel braided ones when I initially did the lift back in 2016 or 2017. Could one of those hoses be bad?
I am grasping at straws because I am out of ideas
You can trigger your own abs bleed while driving. I do it at work in the bigger trucks. I will hit around 40-50mph then slam on the brakes in a grass section just off the road. It will cause the abs pump to activate and bleed to unit. Do that a few times then rebleed the system at each of the calipersI am experiencing the same issue. I thought it was a fluid problem. I've flushed the whole system, pedal is still sinking.
my issue is air is in the ABS unit. I cracked the lines at the aluminum box and confirmed there IS air in the system. The master cylinder just doesnt have enough throw to burp it out or the air is stuck in the valve body.
I do not own a motive power bleeder and OBDtool capable of triggering the ABS system so I scheduled an ABS Bleed with the dealer for Tuesday this week, I'm going to have them do the airbag recall while it's there... because I still haven't had time to get that taken care of.
...Will report back after the $179 minimum charge.
Remind me what dealership your at so I can avoid lolYou can trigger your own abs bleed while driving. I do it at work in the bigger trucks. I will hit around 40-50mph then slam on the brakes in a grass section just off the road. It will cause the abs pump to activate and bleed to unit. Do that a few times then rebleed the system at each of the calipers
Lol some of the bigger box trucks don’t have an option to do an abs bleed thru the computer so it has to be done manuallyRemind me what dealership your at so I can avoid lol
I did this with my JKU, took what I needed to bleed the brakes with me to a dirt road that doesn't get used much and could up to speed. Made sure the reservoir was topped off, got up to about 50 then slammed on the brakes, checked the reservoir level, repeat and bled the brakes, repeat once more.You can trigger your own abs bleed while driving. I do it at work in the bigger trucks. I will hit around 40-50mph then slam on the brakes in a grass section just off the road. It will cause the abs pump to activate and bleed to unit. Do that a few times then rebleed the system at each of the calipers
hope ABS bleed takes care of it. replacing the master cylinder isn't too much effort and cheaper than paying dealer labor prices.The dealer just called.
To my shock - did the "gravel road to trigger the abs" then bleed. The pedal is still the sinking.
They want $11XX to replace the master cylinder
which they say may be "bypassed" due to a seal failure.
I can 100% confirm there is air trapped in the brake system at the hardlines to the abs unit.
So I'm out $230 for their time?
Looks like yet again I am going to fall back on the old reliable - "if you want it done right, do it yourself"
So these are my current thoughts:
Step 1) get the jeep back from the stealership.
I understand paying for the techs time, but $230 for them to not be able to confirm with confidence that all the air is out of the brake system, not pressure test the master cylinder, and just recommend I "throw money & parts at the problem" is what am I paying for? Has anyone successfully negotiated the technician charges for failure to perform services?
Step 2) I plan on purchasing a motive power bleeder (Unless the community here recommends otherwise)
Step 2a) I will consider purchasing a scantool capable of triggering the ABS pump (Again unless the community here recommends otherwise)
Step 3) I plan to pressure test the master cylinder as a first step check in sanity
Step 4) I plan to pressure bleed the entire system
Step 5) I plan to enjoy my jeep with restored confidence in braking performance and a firm pedal
