jesse3638
I'm in the middle of swapping tires Cooper STT Pros to Toyo Open Country R/T Tail, both 37x12.50 17 on Raceline Monster bead locks (steel rings). Cooper's are know for their thick bead these Toyos are much thinner. Just finished up the second one and heard what I though was air escaping. I sprayed soapy water and sure enough it's leaking air between the rim and ring. Have not had this issue on the last two sets of tires I had on there. I torqued then to 20'lbs initially. Unbolted the ring to check that I had the bead seated correctly reinstalled it and torqued them to 30'lbs. Still leaking. Any idea what the problem could be or a solution? I'm wondering if the thick beads on the Coopers deformed the rings causing them not to seat properly now with the thinner bead and i need to replace the rings? Would driving around with weight on it deform/flex the bead to seal it up? Any help is much appreciated. I don't want to have to fill my tires daily.
