They raise the tie rod 1.5”. I have a Currie tie rod, which is oversized (1 5/8”). I also have a Prorock44, which has a thick cover that sticks out a ways. The raised tie rod is now at the same level as the part of the diff cover that protrudes the furthest. So full steering lock to the left has the tie rod hitting the diff cover before the steering stops contact. I could drill and tap the stops and stick in bolts, but my steering radius is going to be huge and probably unacceptable. I’m noodling solutions now, but may have to ditch the Rancho knuckles and go back to OEM. We’ll see.
That's right. I forgot about that. I'm running the ProRock with Rancho knuckles as well, and had a similar issue with the stock tie rod bracket sticking inward and doing the same thing (https://wayalife.com/showthread.php...tting-ProRock-cover?highlight=rock+hard+clamp). It never hit bad enough to limit my steering though. Hope you get it fixed easily.
