Verifying some offset/backspacing info and came across this - it's like Offset and Backspacing for Dummies!
Figured it deserved the revival!
Donnie
Running stock width full float Axles on 35" tires with 3.5" Lift.
The Axles require 8x6.5 LUG what Backspacing and Offset Should I go to avoid Tires sticking out of the Fender and No rub
Note: Currently running 20x9 with 5.71 backspacing and +18mm Offset and tIres do stick out a little bit from from fender but no rubbing.
Hi, JK007-
How far out would you say your current wheels and tires sit outside of the fender and is this with the aftermarket the aftermarket axles or factory axles?
I would say 1" with factory Axles and stock Flares.
