mr.travo
I FINALLY bought the Auxbeam GA80 8 gang switch for my JK. It came in yesterday and I am already modifying things in the kit to be better than they came. The battery wire they provide would probably work for a side by side or 4 wheeler, but I wouldn't trust it in the jeep. It's some pretty short and dinky 8 gauge wire. Already I am going to get some pure copper 6 gauge instead. I found this Amazon 6 gauge wire for a decent price.
I also had ordered 2 sets of Auxbeam's LED lights. These in white and these in amber. I am pretty impressed with the wiring for these lights and the harnesses are very well put together. The downfall is in the instructions it doesn't provide a wiring diagram on how to wire them up to the Auxbeam switch panel. The harness has a switch and relay already mated up to everything. When wiring it up to the Auxbeam switch panel, do I keep the provided relays intact? I am assuming so since the GA80 doesn't seem to have any built in relays. I know I will be cutting out the switches and terminating those ends with heat shrink. I am pretty good at wiring but I would like some other input so I don't accidentally catch my Jeep on fire, LOL!
As for the mounting plate for the GA80 box under the hood, I went ahead and ordered this mount from Metalcloak as I have already relocated my vacuum pump up to the engine bay. I will drill the proper holes in this mounting bracket for the Auxbeam. I liked this one because it also has another mounting tab so it has three points of contact to the body instead of just two.
Other than that, I am just waiting on all my parts to finish the build. If someone with a little more knowhow and can confirm that I need to keep the relays for the lights or not that would be great.
Thank you all for your help!!!
