Jsouder53
The bolt on coilovers still have 11.5 inches of wheel travel vs the autolynx 10.5 limit.Only if you were planning on running something like a DTD or something with more than 13” of travel.
15" on the JL.The bolt on coilovers still have 11.5 inches of wheel travel vs the autolynx 10.5 limit.
Ah yep. For some reason I thought the bolt ons weren’t quite the full 11.5 once everything is dialed with bumps and whatnot. Now I’m gonna have to go experiment . When I get my jeep back from the shop, maybe I’ll post up some comparison pics with measurements.The bolt on coilovers still have 11.5 inches of wheel travel vs the autolynx 10.5 limit.
Did you ever try this out? Still using them? I got a set of used teraflex disconnects that I have used for 2 years. I had to replace the bushings a couple times... and they have worked! Wondering about the measurments you got?Ah yep. For some reason I thought the bolt ons weren’t quite the full 11.5 once everything is dialed with bumps and whatnot. Now I’m gonna have to go experiment . When I get my jeep back from the shop, maybe I’ll post up some comparison pics with measurements.
Thanks for the reminder. I did go out and take some measurements but got sidetracked.Did you ever try this out? Still using them? I got a set of used teraflex disconnects that I have used for 2 years. I had to replace the bushings a couple times... and they have worked! Wondering about the measurments you got?
These may be my next purchase... I think I can live with that!Thanks for the reminder. I did go out and take some measurements but got sidetracked.
I can’t speak for how they work with bolt on Coilovers but, the shocks I’m running have a 12.75” travel length.
disconnected completely (unbolted from the axle) I get about 12-5/8 on the driver side before things start to bind and it stops. Passenger side is right at 12” (assuming because of how the track bar pivots on that side at the axle.
Connected to the axle and ran with the auto lynx open, I got exactly 12” of travel on the driver side and about 11-1/4 on the passenger side. So they are limiting my travel some, about half an inch which for me, it’s not enough for me to notice or care.
I took these measurements off of the visible shock shaft from the bottom of the shock body to the collar on the shaft. Probably a better and more accurate way to measure but, that’s what I ended up with.
If you’re running long arms and long Coilovers or long travel shocks and really want all the flex you can get, these aren’t for you. If convenience is a factor and you don’t care about losing 1/2-3/4 of shock travel, I think they’re just fine for the average guy.
