There are a lot of different things that can trigger that light, likely just a faulty impact sensor. I would recommend getting it scanned sooner then later as none of your airbags will work until that light is back off. In the mean time you can check to make sure your seat belt sensors are plugged in, you could also check your impact sensors to make sure they are all plugged in all the way. The easiest way to figure out what it is, is to get it scanned! If you can get the code the repair will likely be simple.
Forget the scanning, you can get body and airbag control codes by using this sequence on your ignition. Put in your key and turn the ignition On-Off-On-Off then back to the On position . The codes will be given in the odometer read out. The code descriptions can be found here... (where I found the sequence) http://www.quadratec.com/jeep_knowledgebase/article-139.htm
Hope this helps! Keep me posted
A bad clock spring will cause a random chime and air bag light up.
That's what I was thinking too.
I'm having the same problem, happened when I snapped my sector shaft on the trail a couple weeks ago. Thinking its the clock spring, dropped it off to have it fixed today. On my other jeep though I had the same problem and it was that one of the sensors needed to be re-calibrated.
