Mine have a lock nut on them to lock in the length and rotation.
It is normal for your joints to swivel like that.
Loosen the jam nut, straighten it out, re-torque....and use some loc-tite. Joint is supposed to be straight or it can be damaged over time.
Anyone know how to adjust lower control arms? I put mine in a couple weekends ago and now I checked to see how everything was going below and I found the following image: View attachment 158455
Any ideas how to adjust them so they're straight up and down?
Is it a length problem or...?
what brand control arm is that? are they all that narrow? it looks much narrower than the joint on my lower control arm
My Teraflex lowers are huge. They take up the whole mount.
They are also shitty. Just because they are big doesn't mean they are good.
Whoa! lol. Not going to bait me into this troll fest.
I ran these RK arms for aver a year and they will stay straight. The trick is to pull the bolt, drop the axle side of the joint, then loosen the jam nut. Offset the joint a little, because when you crank on the jam nut it's going to want to rotate the joint a little bit. You want to offset it enough so that when the jam nut is bubba tight, the joint is straigh and then re-mount. They will stay straight if tightened this way, I also used a 3 foot long pipe I've the handle of my wrench to get the jam nut tight enough.
