Upper radiator hose. The angle was terrible as you can see and from what I can tell, the 3 bolt thermostat flange is specific to the GM 8.1 engine. There are no aftermarket swivel housings or adapters available. So…
Chopped this little guy up
Rotated it clockwise and welded it back together
DUN. I was able to search through hoses at a local parts store and found Gates 22641 which fits a Cherokee with the 4.7 engine. Keeping it Jeep!! Haha!
I thought I had the steering mount all done. Wrong
The PSC box is a larger casting with a larger end cap. Fought me every inch of the way fitting it. I pity the next 715 owner that wants to modify for power steering. UGH
Had to make some inner box spacers out of some 1018 solid bar which then got drilled out
It simply WOULD NOT fit up against the backside of the frame and the end cap on the box. So away it went…
Finished the bed mount repairs on the passenger side today so the bed is fully bolted up now
Addressed the 4 lift points on the upper rail of the bed. I believe they were in place to assist with lifting the truck into a cargo ship for transport. Every one of them was pretty bent and banged up
Cut out some 1/8” plate supports…
Hammered the stock supports back to vertical and welded them in. Done
